HC in the offing
Discussion in 'Home Cinema Building DIY' started by Gojira, Jul 18, 2002.
  1. Gojira
    Gojira
    Jul 13, 2002
    19
    Hello all.
    My wife has funally caved & it looks like I will have a shiny new Panny ATE100 from the end of August.
    This gives me the better part of a month to convert my spare bedroom (3.5m x 2.5m) into an all singing, all dancing home cinema.
    Fortunately, I have for the last ten years, been unconciously building up to this moment by buying ld players, dvd players, dd/dts amps etc....
    Now comes the tricky bit.
    The projector will clear out my meager savings & leave me financially committed for the next 9 months (if u know what I mean...) so I will be converting the room on a budget of, well, sod all.
    I have designed the room from top to bottom with each part made up from stuff begged, borrowed or whipped off a skip.
    My designs for the room, cabinets and even the PJ bracket, will be posted over the next few days & I would invite your comments good & bad. I will also post photos on a website when I actually get work done.
    My thanks for any advice you can give.
    Regards
    Dylan:D
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Sounds good.
    Look forward to the pics.
  3. Gojira
    Gojira
    Jul 13, 2002
    19
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,557
    UK.
    +3,058
    Looking good - at least your first thoughts appear to be soundproofing which is always a good idea if you have neighbours!
    2 layers of plasterboard I take it?
    Gary.
  5. gwbailey
    gwbailey
    Yep, looking good!
    Just out of interest what was the size of the Rockwool you're using?
    PS, keep us updated;)
  6. Gojira
    Gojira
    Jul 13, 2002
    19
    Just one sheet of plasterboard - because of the way the house is situated, there are about 2 layers of brick, one breeze block & two plasterboard walls between me and the neighbours (after 2 years I have never heard a thing from that side). And thats before the new wall! Overkill anyone?
    Also, there are no joining rafters as it is an overhanging room and built on what looks like a steel plate!
    The rockwool slabs are from Wickes and are 50mm thick so they are not too tight behind the wall as I read you need to leave some air to circulate...
    Will post further design pictures soon when my scanner works again!
  7. Gojira
    Gojira
    Jul 13, 2002
    19
    Here's a picture of what the finished room will (hopefully) look like.
