having my NEC 42" fixed
Discussion in 'Plasma TVs' started by DarkBytes, Feb 10, 2005.
  1. DarkBytes
    DarkBytes
    Hi all ,
    1st post here , and I am afraid I am going to ask lots of questions , in the hope of drawing on your wealth of plasmatic knowledge :)
    So I have a very old , but extreamly well built NEC plasma , its A plasmasync 4210w 42" screen. of course it is no match for the high end plasmas of today , but it would definatly give the 1k range a run for there money. This puppy cost 8 grand when it came out i believe.
    So it has developed a fault , on the screen a strip about 3 cm wide has appeared , it runs a little less then half way up the screen and is slighyly to the right.
    This I am informed , is due to a blown ribbon that is bonded to the panel ( essentially there are ribbons accross the top and the bottom of panel that control the picture for that area.
    Now a chap in london contacted me , informing me that his company can repair this fault. they have a machine that can remove bonded ribbon and replace and re bond it with another.
    Now NEC dont reapir this model anymore so I am going to go for it.
    but I have no box , I was wondering if anyone knows of a place where i could order a flat pack box ?
    Or is there anyone in the peterborough area , who could perhaps lend me there 42" box ( will gladly give recompense).
    anyone ?
    or have any of you had simuler repair jobs done ? apprently its quite a new technique ?
    Also I am looking for a table stand for the plasma, its quite old so I think that may prove tricky , as I think you need a specific type for the NEC ones.
    anyway thanks for your time, I look foward to your comments
    nice to be here :hiya:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Welcome mate, anyone who repairs plasmas should be able to offer you a soft bag or hard flightcase to be sent out for a small charge.
    There are a few universal stands partington feet etc and Unicol probably do one see www.unicol.com email them the model number and they will be able to quote you a price etc.
  3. craigz
    craigz
    I also have an nec in need of the doctor - a 42 pd2. Did you source a falt pack box? And could you let me have the contact details for you repairers
    Thanks in advance.
