I use an HTPC that goes back to S3 sleep when not used for 15 minutes. This has been my setup for years, through various cases and hardware components.
Something has changed, either because of recently upgrading to Windows 11 (most likely candidate) or migrating the streaming devices in the house to a newer version of Kodi.
I use the add-on, PlexKodiConnect.
Issue
An addon in Kodi, 'Advanced Wake On Lan' wakes the PC up as the app starts. I can then browse for media to play, I think I have a 15 minute window before the PC falls back to sleep, in line with the settings above.
If I play a TV show or film, as soon as it finishes, I can't play anything else. The PC has gone back to sleep the second the show has stopped streaming.
Previous behaviour
I believe, I used to get the 15 minute timer at the end of the show, to get chance to pick another one.
What have I done?
The PC isn't falling asleep during streaming, but my assumption is that once the show finishes, the running task that would show up within Powercfg is finished, and the PC is immediately going back to sleep.
Does anyone have any other thoughts as to how I can get a 10 minute window after streaming finishes, to pick the next episode?
Issue
Previous behaviour
What have I done?
- Enabled 'System unattended sleep timeout' within Control Panel, and also set this to 15 minutes
- Ensured that 'Multimedia Settings > When Sharing Media > Prevent Idling to Sleep' is enabled
- Tried various options within Advanced Wake On Lan to send continual packets.
- Had a brief look at Powercfg /requests
