Having AV terminal troubles w/ Panasonic Plasma
Discussion in 'Plasma TVs' started by JHARDMAN, Sep 11, 2005.
  1. JHARDMAN
    JHARDMAN
    Panasonic Plasma TH-42pwd7uy, the av terminal stopped showing video, sometimes it would show a black and white picture with jumping horizontal lines. Moved the AV terminal from slot 2 to slot 1 and it worked. The next time I turned it on, no video again. I then pulled the terminal out and pushed it back in and it works fine, for now anyway. Any ideas?
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    might of been a dodgy connection, and will probably be fine, but if it happens again contact the retailer.
    edit: just re-read and looks more suspect than i thought, but see if it happens again first :)
