Having a prob with new panasonic ds65
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jamin6721, Oct 3, 2003.
  1. jamin6721
    jamin6721
    Hi, I got myself a panasonic ds65 after reading good reviews on here. The camera is fab, but im having a small problem with windows movie maker capturing:
    If i capture via the WMM wizard and choose
    "digital device format (DV-AVI)"
    "capture parts of the tape manually all works fine". ( although there seems a slow delay with the onscreen cam controls and the speed the camcorder responds )
    But if I choose "capture the entire tape automatically"
    the camera "rewinds tape" as indicated in the wizard with the tick , then the tick moves down to the next step "capturing video" and before the camera starts play back of the tape I get an error saying:
    "The specified Video Device is not responding. Verify the device is connected properly and turned on, and try capturing again"
    It seems as if WMM timesout after about 1 second if the camcorder cant start playback of the tape fast enough after rewinding.
    This happens 90% of the times i try?
    Also when i send my edited file back to the camera i miss the 1st couple of seconds because WMM seems to send the stream before the camera is ready (started recording).
    Do you think theres a fault with the ds65 mechanics working to slow?
    Is there anyway to slow down / delay / increase timeout in WMM?
    I cant find any info on this on the net or ms support, so if anyone could help i'd appreciate it
    thanks
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    First thing to do is download the free upgrade to Movie Maker 2 from the MS web site. This will give much better features and quality.
    There will always be a slight delay between the software controls and the camcorder getting going. This IMO is not a fault, just the fact that the PC has to send the device controls after proccessing the fact you have requested them.
    Always record a few seconds of blank at the start & end of a movie before sending back to the camcorder. This will stop you missing the start of your footage.
    Mark.
  3. jamin6721
    jamin6721
    Thanks mark, good idea. A few seconds of blank before the vid will do the trick :). At least I know theres nothing wrong with the camcorder.
    I upgraded to WMM2 and yer it is miles better.
    thanks for putting my mind at ease mate.
    Ben
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    Glad to be of some help! :cool:
    Mark.
