Have you got 1:1 native resolution
Discussion in 'Plasma TVs Forum' started by rscott4563, Oct 28, 2004.
  1. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    I've got a couple of really simple questions....
    Do you have a 50" panasonic 6 series plasma?
    Are you feeding it with a scaled image, i.e from a PC or video processor?
    Have you got 1:1 mapping, i.e 1366 x 768?
    Is this through the DVI or VGA input?
    And finally what are your settings, some thing along the lines of:
    V Sync, V Front, V Total, H Sync, H Front and H Total, and also the plasma serice menu settings for H Pos/V Pos/H Size/V Size, basically just all the info you can give me.... :lease:
    Ryan ;)
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Ryan, I have 3 'out in the field' setups as you describe, all with iscan HD all on analogue. They were so little trouble to set up like that I have never troubled to write down the settings. The only 1 I've had difficulties with was a Fujitsu, which will not take native at 50Hz, only 75, and the iscan was a bit dodgy. I have that one here now, it won't lock at 75Hz. None of them have shown any interest in DVI, (plasmas, not clients) and we've made do with analogue. We do have 1:1 mapping, even the fuji eventually!
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    Ryan,
    Just looked at my notes and I haven't written this down. I might...an this is only a might...be able to pop in t a dealer this weekend who has a 50D6 and an HDP Pro to see what it's at. I'll then at it to my excel sreadsheet for posting on the new support forum. That Lumagen forum is going to go live very soon. Just waiting for feedback from Jim.
    Gordon
  4. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Hi Gordon
    Sounds great, I'll keep my fingers crossed.
    1:1 mapping with DVI @ 60Hz and analogue RGBHV @ 50Hz would be great... :D
    Ryan :smashin:
  5. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Gordon
    Did you have any luck having a try with the Panny and Lumagen at the weekend?
    Also any more news on when the Lumagen forum will be live?
    Ryan
  6. Maninblack
    Maninblack
    Sep 24, 2002
    458
    +17
    Is that with all Fujitsu models?
    I have 1:1 at 60 Hz, not at 50.
    If I can get it set up at 50(which I believe is not possible?)
    Have you some settings for 75?
    What would I benefit by using 75?
    When you say you had 1:1, was that at 50, 60 or 75? or all!
  7. Maninblack
    Maninblack
    Sep 24, 2002
    458
    +17
    If you can shed some light on this MAW it would be appreciated, thanks
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Busy day, no email notification, I'm not ignoring you! Native res works at 60Hz and 75 Hz, not at 50, you can't get the image in the right place. 75 being a multiple of pal frame rate you get smooth pans, no judder, so that's what you want for 25fps stuff, set the res, then go into framerate, 50hz, and lock it at 75Hz. You will now be able to set the picture up correctly. So far so good, but if you have software verion 1.12 03 4.01.08 it will miraculously unlock and revert to 50Hz every time you change inputs, and the picture will jump about 60 pixels to the right. The iscan will think it's in 75 hz still, you have to reset to 50, then reset to 75 to get it back. The screen info will tell you the real state of affairs. If you have this trouble you will need to update the software. Pain in the butt, but it will work.
  9. Maninblack
    Maninblack
    Sep 24, 2002
    458
    +17
    Thank you for the information.
    I didnt think you were ignoring me!
    Everyone is so helpful!
    Is that 1:1 pixel mapping achievable then at 75?
    I have it fine at 60 and 50 locked to 59.94.with the Iscan.
    Is the same achievable with 50 locked to 75?
    I will check my software version, if its ok maybe we can go through the settings to fill the screen correctly.
    I like my image quality, but it judders, eliminating the judder has reduced the quality so far, perhaps this is a better solution to try?
  10. Maninblack
    Maninblack
    Sep 24, 2002
    458
    +17
    Hi Maw, have you any comments on my questions?.
    If you have I will be greatful.
  11. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Sorry, this thread does not email me properly, got the latest, but not the previous. Yes, it works at 50Hz locked to 75hz, judder is noticeably better than at 60Hz. Feel free to email, I will give you my phone number.
