Have upto £200 to spend on a DVDplayer- Any advice??
Discussion in 'Blu-ray & DVD Players & Recorders' started by bingle, May 13, 2004.
  1. bingle
    bingle
    I plan to buy a Multi-region DVD player and have upto £200 to spend. Any advice such as what would give me best value for money etc, will be greatly received. Thankyou!!!
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    what display will you be using? Different players are better for different types of display
    ad
  3. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    251
    Was in Musical Images in Beckenham the other day and they had the HK 25 for 175.
    I have nothing to do with M.I.
    Fish
  4. Promised Land
    Promised Land
    May 4, 2004
    215
    16
    The Thin Line
    Toshiba make some great players for a lot less than £200 and that's including component out(if you have a display that takes component in).
  5. bingle
    bingle
    i'm using a 32inch sony wega tube tv , about 3/4 years old, tho i can't remember the model no off hand.
    Thanks for ur advice, :)
  6. samhain
    samhain
    Apr 1, 2004
    2,786
    South West Scotland
    +131
    Toshiba release the SD 240E this week which is Progressive scan out on PAL and NTSC, for how much I hear you cry £65.00 (Even if you don't need those what a bargain !!)
    :D :D :D :D :D :D :D
  7. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Have you any links m8.
  8. samhain
    samhain
    Apr 1, 2004
    2,786
    South West Scotland
    +131
    Sure mate, don't know who they are but if you search on the net and are familiar with a supplier then it's something to think about.
    I have had Tosh DVD players since the year dot and they never fail to impress. I fancy one too for my Plasma, but the 500 SD looks tempting at £180 which has a 3:2 pull down on progressive NTSC material.
    http://www.leconcepts.com/dvd/toshdvd.htm
  9. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    probably one of the more expensive toshibas is ideal..... I doubt prog scan really matters since i doubt the tv can accept it
    ad
  10. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  11. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    Well, Richer sounds are doing the Pioneer 565 for £148 now. IMO they are an absolute steal at that price and I was so impressed with the first one, I bought another for the bedroom!
    The toshiba mentioned above is also well worth a look, especially at £65!
  12. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    Can anyone explain what "3:2 pull down on progressive NTSC material" means, please? :confused:
    (I'm intending to play on Panny PW6 plasma, if it's relevant.)
