Have to go round in circles to get all channels!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Gadjet, Jun 1, 2003.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Totally baffled
    I can only get all ITV and BBC channels by getting Channel 5 or 4 first and then selecting one of them. Cant get any of the stated channels from tv guide or using numbers. First it was only ITV now its BBC channels as well. Wierd can anyone help please, is it my box (panasonic digi) or anything else?
    Phill
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    It's most likely your Panasonic box. It is incompatible with certain LNBs... they don't switch to low frequencies correctly on command with the Panasonic box. The LNB probably needs changing. Contact a local sat specialist: www.apsiuk.com
    Hope this is of some help ;)
  3. staxdoobie
    staxdoobie
    May 7, 2003
    325
    +35
    Sounds exactly like the problem I'm having. Been having intermittent problems with ITV for about a year, but it's been liveable with. Now that the same has started happening with BBC channels, I got annoyed and rang them up. Sky absolutely refused to take responsibility, but are clearly delighted at the thousands of £65 call-out fees that will result.
    I have a Grundig digibox. Will the fitting of this SatCure filter solve my problems too?
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    I'm not sure about this one as Grundigs don't have documented LNB incompatabilities... it may just be that your dish needs realigning in which case get a local professional to do it :)
  5. staxdoobie
    staxdoobie
    May 7, 2003
    325
    +35
    Would I not be able to tweak the dish myself...?
    How hard can it be?
  6. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
