Have lost Film4, Itv4 etc
Discussion in 'Freeview & YouView' started by FarehamLad, Mar 8, 2013.
  1. FarehamLad
    FarehamLad
    Mar 8, 2013
    Hi guys,
    Its been a couple of days. It was there and then gone. Rest all frequencies are fine. I have used this aerial for many years and has no issues with the switchover.
    Info
    Local Transmitter Rowridge (Isle of Wight) no problem reported as per Freeview when i phoned.
    Neighbors: Are getting channels.
    Missing Com 6, ARQ B, UHF Channel 29 538MHz (no signal)
    Scanned multiple times. Changed indoor Ariel. Not working
    Switched to Spare Freeview box for scanning, did not work
    TV---> Technika (from Tesco purchased about 4 months ago) 22 inch TV inbuilt Freeview tuner
  2. Rodders53
    Rodders53
    Dec 8, 2007
    5,175
    Bedford
    +930
    From your description your aerial is the problem.
    Room / set-top aerials are seldom ideal and often need re-orienting / slight movement / relocation to get good results on the different transmitted frequencies.
    Take the TV to one of your neighbours who uses a loft or (better) a roof aerial and tune it all in. Then never, ever retune it again if you lose a channel.
    Try your room aerial with the rods vertical rather than flat/horizontal as this may be better now Rowridge has been re-engineered to transmit the best signals in Vertical Polarisation. In any case, moving the aerial to find the 'sweet spot' for your missing channels is one solution. [The other is to get a proper rooftop or loft aerial installed].
