Have I set this system up right?
Discussion in 'Cables & Switches' started by barry roubaix, Jan 20, 2004.
  1. barry roubaix
    barry roubaix
    Just bought an LCD TV, DVD player and Sony Freeview box.
    As per What HiFi recommendations I've connected the DVD directly to the RGB scart on the TV. The Set top box is connected to the second TV scart and the Video recorder to the set top box.
    When I record on the video I only get sound - no picture?
    Everything is connected with Ixos scarts
    Also, would these scarts benefit from being routed away from electrical cables and Ac/Dc transformers (the TV has one).
    Any advice would be greatly received, as there is a programme I need to record tonight!
  2. Serpico
    Serpico
    Jun 22, 2002
    345
    Hull
    +7
    Check to make sure the Scarts between you r STB, VCR and TV are connected properly. Sometimes you can get sound and no vision when a Scart is not quite all the way in.
  3. bobbypunk
    bobbypunk
    connect freeview to av2 on vcr (or whichever one states IN/OUT)
