have i ordered the wrong size screen?
Discussion in 'Projectors, Screens & Video Processors' started by davyb, Dec 12, 2003.
  1. davyb
    davyb
    Hey guys!
    I have just ordered the z2 from ivojo and a screen from drh!! Cant wait for them to arrive!!! Problem is, that I am not sure if i have ordered the right size screen??? I have a maximum throw distance of 3.1m. I have ordered the manual pull down slimline screen from drh which has a viewable area of 203cm(width) x 114(height). Have I ordered a screen thats too big?? Should I have gone for a size smaller?Please give me some advice before it is too late!!!
  2. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    dont worrie you will be able to project that size from the distance.
    but how far are you going to be sat from the screen?
  3. davyb
    davyb
    The projector will be above my head hopefully, or in line with me using the lens shift. That will be a distance of about 3m clancol. Why do you ask?
  4. davyb
    davyb
    Any more feedback would be appreciated!!!
  5. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    You'll be fine.
    My throw & viewing distance are siimilar to yours and I've got the smaller 173cm wide DRH.
    I'm really pleased with my set up and the experience it gives but from the Z2 is projecting pretty much the smallest image it can at that distance. There is no reason why you shouldnt go with the bigger screen as I have zoomed the image to max, just to see, and it was fine. Well apart from being too big for the screen :)
    Pic of screen here
  6. davyb
    davyb
    Thanx weirdfish. I am gaining confidence minute by minute.
    davyb
