Have I made the correct choice for cables?
Discussion in 'Cables & Switches' started by Nick_T, Nov 26, 2004.
  1. Nick_T
    Nick_T
    Nov 3, 2004
    115
    16
    Cambridge
    I am building a system comprising of:
    Panasonic TH-42PW7B Plasma Screen (with Component video BNC terminal board) - http://www.av-sales.co.uk/plasma/html/panasonic_th-42pw7b_plasma.html
    Canton Movie CD 2.22 speakers - (http://www.av-sales.co.uk/html/canton_222.html)
    Panasonic DMR-E55EBS DVD Recorder (used as DVD player) - (http://www.av-sales.co.uk/html/panasonic_dmr-e55ebs.html)
    and as another source I have SKY+.
    I have put together a list of cables to connect all of this equipment together and would appreciate someones opinion on my choice. Is it a good choice? Have I gone over the top with some of the cables?
    Here is my current list:
    • QED AV21 Scart to Scart Fully Wired (Sky+ -> DVDR) 1m @ £50
    • QED QUNEX Component P-CV2 (component video connection from DVDR to Plasma) 1m @ £80
    • QED QUNEX P-SW sub-woofer cable 6m @ £40
    • QED Silver Anniversary Speaker cable (for L+R and centre speakers) @ £5.50 per metre
    • QED Micro Speaker Cable (rear L+R) @ £1.75 per metre
    They can all be found here: http://www.av-sales.co.uk/html/qed.html
    If anyone can recommend a better choice then please let me know. I'm mainly worried that I am spending a lot on cables where I don't need to be :confused:
    Cheers!
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I would suggest that you have a look at the component cables that Mark Grant supplies in the Cable Powerbuy forum as they are absolute top notch quality but will save you £30 over the QED.
    I am not sure whether you need spend that much on a scart cable for connecting the Sky box to the DVD Recorder as whilst it is always a good idea to buy the best connectors that you can afford for DVD replay I am not convinced that the same applies to satellite broadcasting as the source picture isn't as good to start with.
    The speaker cable should be fine, but I would say that as I also use Silver Anniversary
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,186
    +3,037
    Also, what about Mark Grant's subwoofer cable at £45 for 6m.
    I wouldn't spend more than £20-£25 on a scart cable.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Mark's subwoofer cable like his other cables is excellent quality at a very good price. I also wouldn't spend more than £25 on a scart cable but I only have a 32" TV. Perhaps the extra would be more worthwhile on a plasma but somehow I doubt it when using a Sky box as a source.
  5. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Not to go on about it too much, but have you considered alternatives to the QED speaker cable? specifically either twin and earth mains cable (at about 20p/metre) or cat5 cable made up as described here
    Both of these methods would be a LOT cheaper, the mains would be indistinguishable from the QED, the cat5 should be an improvement.
