hi,
Was in Richer Sounds today and bought my self an amp (NAD C320 BEE) and some speakers (MS 902M).
They had non in stock so have had to order them in (therefor can change my mind if i wish).
I had done quite a bit of research on the amp, but the speakers less so. After a bit of a talk the staff member in RS advised the MS speakers so i took his advice and bought them. However after reading around i'm a little worried that the speakers might not be up to the job. Is this the case? £150 is my max budget should i maybe have gone for something different?
The room is small and i mainly listen to a wide range of music, but mainly rock/blues/hip hop.
I think my main concern is with their bass capabilities, some have suggested this area is weak.
Any help would be much appreciated.
Thank you in advance.
