Have I made a mistake?
Discussion in 'Cables & Switches' started by Jonesthegas, Jun 6, 2004.
  1. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    696
    Newcastle upon Tyne
    +26
    I'm having an extension built as a home cinema room. For a 7 speaker setup, the electrician has run 7 lengths of QEDsilver anniversary cable to each speaker behind a stud wall and under the floor.
    However, I now realise, for convenience, he has run several feet of the 7 cable together in parallel in a bundle.
    Will there be significant interference which will affect performance? Its done now, it would be a major upheavel to undo this :mad: .
    Martin
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    are there mains cables in those bunches? If not you are likely ok
    ad
  3. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    696
    Newcastle upon Tyne
    +26
    Mains cables are not part of the bundle.
    Martin
  4. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Don't panic, as buns says, as long as it isn't run parallel to any 240v cable you'll be fine...
  5. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    696
    Newcastle upon Tyne
    +26
    Good news.
    Martin
