Have I made a Bolox
Discussion in 'Cables & Switches' started by pure_geordie, Aug 4, 2006.
  1. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    :eek: Hi chaps, I have purposely only ran Component/HDMI cable runs for my latest build. The thing is I may want to use my projector for satallite/freeview and Xbox 360.
    Is this possible with the cables I have ran or not. will be very difficult to run an older type cable to accomodate these options:D
    Thank you
  2. JohnWH
    JohnWH
    Jan 23, 2004
    1,826
    48
    St Albans
    +82
    The component cables should do the trick for you as even if you don't have component out on you sat/freeview box you can get converters which will do the trick for you. Hey, you could even just use one of the component cabes for a composit feed if you get desperate (not recommended though!)
    John.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    should be fine a few freeview boxes output component and there are upscaling AMPs aplenty
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,751
    The Borders
    +3,519
    Hello pure-geordie
    Use the JS-Technology RGB2YUV converter on the Output of your RGB SCART enabled devices - see http://www.js-technology.com/produc...id=36&osCsid=61bf136c698175db7b534b33d8c99cd0
    As Horny says you can purchase a Freeview box with YUV Out on SCART - see http://www.netgem.com/EN/produits_iplay.php?
    Your Xbox360 has an optional YUV cable so that's easy enough too.
    Then all you require is and AV Receiver with YUV switching or a decent quality external switch - see http://www.zektor.com/hds41/index.html
    Simple really.
    Joe
