Have I killed my ipod
Discussion in 'Headphones, Earphones & Portable Music' started by KAZER, Dec 19, 2006.
Tags:
  1. KAZER
    KAZER
    Feb 4, 2005
    693
    28
    Essex
    +27
    Hi All
    Please help.
    My ipod nano has stopped responding and shows as being in "disk mode" the back light no longer goes on and all is in monochrome. How can I get it to go back to "normal mode" as it were or is it were.
    The exact text appearing on the screen is as follows.
    Disk Mode
    (tick sign)
    OK to Disconnect
    Kazer
  2. djmetsandy
    djmetsandy
    Jul 30, 2006
    947
    Perth, Scotland
    +35
    this image?
    [​IMG]
    according to apple.com...connect your ipod to the pc?
    "Disconnect iPod from the power adapter and connect it to your computer; the screen on the iPod will change and say "Do not disconnect""
  3. Vini
    Vini
    Nov 25, 2005
    1,616
    48
    UK
    +66
    I've got my new nano stuck in Disk Mode and am trying to disable it so Itunes will recognise it again, I've been at the above stage 3 or 4 times, and just flicked the hold switch and did the Menu & Select button reset...
    Still in disk mode, but it got past the above screen.
  4. KAZER
    KAZER
    Feb 4, 2005
    693
    28
    Essex
    +27
    Thanks djmetsandy
    All fixed now. :)
    Kazer
  5. djmetsandy
    djmetsandy
    Jul 30, 2006
    947
    Perth, Scotland
    +35
    you are welcome!
