Have I bought the wrong RAM...help !!
The Dark Horse
Hi all
I've bought 4gb memory for my white 13" macbook (2.1MHz) from Crucial. Not realising that Crucial had a scanner to assist with buying I bought what I thought was the correct memory -
2 x 2GB 200 PIN SODIMM 256MX64 DDR2 PC2-5300 DUAL DIE (part no CT25664AC667)
I have since used the scanner from Crucial on my Macbook and its recommending something else -
2 x 2GB 200 PIN SODIMM DDR2 PC2-5300 (part no CT791300)
I've not tried fitting it in case it knackers it. Will the one I bought work or have I bought the wrong one?
Help please !!!
Steven
Senior Moderator
No you haven't bought the wrong one
In fact, both of the part numbers give you the same ram to buy on the Crucial site
The different part numbers is probably because they are branding it as for Macbook, when in reality any notebook ram module using DDR2 5300 667mhz will do. I bought mine from play.com as its cheaper than Crucial online
The Dark Horse
Really....phew !!
So why does the one I bought say 256MX64 DUAL DIE in the title and the one they recommend doesn't?
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
