Have I achieved 1:1 pixel mapping?
Discussion in 'Projectors, Screens & Video Processors' started by Crocodile JD, Oct 13, 2003.
  1. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Hi guys
    Need some help on this, I never really understood screen resolution issues.:blush:
    I've got a Sanyo PLV30 LCD PJ which has a native res. of 800x600 which is the SVGA standard I believe. Over the w/e I hooked it up to my PC which I set to output 800x600 on screen res with 32 bit true colour at 75kHz fequency. I then ran PowerDVD to playback DVD,s. I configured PowerDVD to playback both 4:3 and Widescreen material at 800x600 (32 bit 75kHz). I also selected the "Don't change aspect ratio" option as well
    The DVD's filled the same amount of screen as it does when I play back via my DVD player, and the image looked pretty good. But the question is have I optimised the PJ performance (i.e. achieved 1:1 pixel mapping) or not?:confused:
    Hope you can help:smashin:
    Croc
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,136
    +1,183
    well you could contruct an image 800x600 of alternating black and white single pixels and see if it displays cleanly.
    You might also find the projector benefits from being fed 60Hz. Most digital panels refresh at this rate regardless of input so if you feed it 75Hz it may well be remapping the frames leading to softening.
  3. johnm60
    johnm60
    Feb 2, 2002
    109
    Shropshire, UK
    +7
    If you want to be sure whether you have a 1:1 pixel mapping, use this guy's test pattern on your windows desktop. I have found it very useful in the past. Remeber to make sure you tile it and not stretch it.
    http://www.marky.com/main/index.html
    John
  4. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Thanks for the replies chaps. It is clearly a more complicated issue than simply setting your PC to SVGA then. I read the thread by Marky over on AV Sience and messing around with Phase etc sounds a little beyond me:(
    I don't even know how to construct the black/white 800x600 image? Am I a lost cause or is it all actually easier than it sounds?
    Croc
  5. cyberheater
    cyberheater
    Apr 3, 2003
    3,206
    Scotland
    +178
    Basically, if the machines native resolution is 800x600 and you've set you PC to that resolution @ 60hz then you should have 1:1 pixel mapping.
    When windows has booted, does all the text look clear and sharp or does some of it appear smeared. If it all looks sharp then you've achieved 1:1 pixel mapping.
  6. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    cyberheater
    I was hoping someone would say that. On boot up, all the text looks sharp, although I,ve been running it at 75 Hz, will change to 60.
    Croc
  7. Kramer
    Kramer
    No need :eek:
  8. cyberheater
    cyberheater
    Apr 3, 2003
    3,206
    Scotland
    +178
    Just copy and past this into a documents folder and then run it as a backdrop with tileing but NO stretching. If there are no flaws in the image then you've proved your 1:1 pixel mapping.
    [​IMG]
  9. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    cheers guys, I'll give it a go
    Croc:smashin:
  10. buns
    buns
    Apr 29, 2001
    6,094
    58
    Belfast
    what does a flaw look like!?
    Ad
  11. theritz
    theritz
    Aug 17, 2002
    2,452
    Ireland
    +27
    Ad,
    fuzzy bands in the image would be a no-no................. should be nice and clear......... btw, using keystone correction will **** up the effect - if you have to use keystone for install purposes, when setting up your !:!, turn off keystone - you can dial it in afterwards if you have to.......................
    Sean G.
  12. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    theritz surely this image (or link to it) has got to go in the FAQ? I personally found it very useful.
    Clint
  13. theritz
    theritz
    Aug 17, 2002
    2,452
    Ireland
    +27
    clintc,
    Yip, an appropriate link to Mark's pattern and instructions added to the FAQ...............
    Sean G.
