Have HD E1, should i Upgrade to EP30
Discussion in 'Blu-ray & DVD Players & Recorders' started by gaz2810i, Jan 18, 2008.
  1. gaz2810i
    gaz2810i
    Dec 31, 2004
    2,557
    103
    London
    +437
    Hi all,
    I have an HD E1 which i am very pleased with but with the price cuts and the free HD DVD deals is it worth upgrading. Is it that much better or can it even be worse.
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,970
    Hi mate :)
    Nothing wrong with the HD E1 fine player :D and like you say your very pleased with it.
    I think the only upgrade with the EP30 is the 1080p.
    Up to you of course,but i say keep the E1. :smashin:
  3. gaz2810i
    gaz2810i
    Dec 31, 2004
    2,557
    103
    London
    +437
    How about Ep35? Any Good compared to E1 I have no need for 1080P unless combined with 24Hz I understand these do this.
  4. Rom
    Rom
    Aug 16, 2007
    2,064
    116
    Sheffield
    +746
    I have the E1 and if I were to upgrade I would only consider jumping to the EP35 due to the ability of outputting HD Audio bitstream. The 30 upgrade isn't that big for me to consider it. If I see an EP35 going cheap I may jump on that :D
  5. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,970
    Hi mate :)
    I see you have a Pioneer 7th gen,can you use the pure cinema on the 1080i signal from your E1 to change it to 72Hz (24fps x 3) to give you judder free playback at all? :confused:
