Dear All,
I am having an issue with my setup and not sure what to do ...
I am not sure even if I have an issue or not either...
I am running my Monitor audio Rx6 with Creek evolution 50A integrated amp and using BlueSound Node as a streaming device. I also have a Marantz Cd67mk2 cd player as a source component as well. If it matter, all cables are solid enough
The problem I am having is the low frequency output of my speakers. They do provide a decent amount of base but in order to get these, I need to stand up at my listening position... the base is always there when I stand up and even walk at in my listening room but got lost when I sit my listening position. The speakers are well aligned, pulled away from the wall at back about 50cm ...the side wall are not not closer than 1m and they are well toed in to my listening position (sorry for poor lighting conditions, and mess around... the last picture is my "ideal" listening position) ... I am not sure .. I think these speakers are fine as well regarded in almost all reviews... no ones says that they are light on base either ... and so, I am not sure if and upgrade to something better would resolve my base output problem...probably not.... but I may have some other gains If I upgrade to something like Sonus Faber Luminas, Focal Aria 926 .. or bit out of budget but Dynadio Evoke 30 (even Evoke 20 sounded very nice in the shop) .. or even bookshelf versions of these and a small sub...
I bought Rx6s five years ago.... actually, I can’t say that I am not happy but sometimes you are looking for some change
I am just wondering If I change my speakers with something new and different sound profile to satisfy my "change" desires... or should I add a small subwoofer to fill the room with more base notes and keep using Rx6s ...
Yes... It is bit complicated .. what would you do ?
