Have 44inch Lg
Discussion in 'General TV Discussions Forum' started by oliver24, Jan 1, 2005.
  1. oliver24
    oliver24
    Just thought I would ask your views,
    Currently have a LG E44SZ21RD Which on the whole is good
    but there are a few points that maybe a diffrent sit will be beter at
    *Contrast ratio, able to display low light pictures with more detail
    instead of just a oil painting effect
    * Bluring with fast moving screen pans, Lg seems to struggle with this
    but maybe this is releated to the rainbow effect?
    * And on that note have the newer DLP tv's got rainbow effect?
    I use a Dennon DVD with MarkGrant Cables, And a Iscan Ultra with Sky+
    and RGB to Componet converter, So that side is pretty much 100%
  2. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    I personally have never seen a LG rear projection tv which has impressed me. LG are normally assosiated for value for money products rather than quality products. Non of the sim2, toshiba, samsung, sagem display any of these trates.
    As you say your AV set up looks more than fine.
    Have you had the set long?
  3. oliver24
    oliver24
    Had the set about 5 months now, On the whole it's a great picture an is very good in normal light, but there is a little detial loss in low light
    I think it is great value for money, and unless the new Tosh,Samsung are a lot better I can live with it
    Maybe I should wait till sky launch HD??, And keep this SD LG till then.
