Hauppauge T-500 remote with MCE question
Discussion in 'Microsoft Windows' started by Stu_B, May 4, 2007.
  1. Stu_B
    Stu_B
    Dec 30, 2005
    88
    Hi All,
    Just set up an MCE box and all is working well. It's using a Hauppauge T-500 tuner and I'd banked on using a normal MCE remote control but I've just plugged the IR receiver into the back of the card and the remote controls MCE pretty well.
    The only issues I've found so far are a lack of 'More info' button and the number buttons enter numbers when trying to search for a program instead of letters and numbers.
    Does anyone know if it's possible to remap remote keys to other functions or to behave in different ways?
    Stu
  2. Stiggy
    Stiggy
    Dec 7, 2004
    6,727
    Sandy Heath
    +1,043
    I thought I'd seen the answer on the Hauppauge forum, but maybe you'll have better luck finding it than I just did!
  3. Stu_B
    Stu_B
    Dec 30, 2005
    88
    Thanks for that I'll go searching
  4. s2martin
    s2martin
    Aug 3, 2006
    49
    Lyme Regis
    +3
