Hauppauge Nova-T
Discussion in 'Satellite TV, Sky TV & FreeSat' started by AndTheAce, Apr 15, 2002.
  1. AndTheAce
    AndTheAce
    I may be barking up the wrong tree here, but can anyone tell me if it is worth buying a Nova-T after all the trouble with ITV Digital?
    The Nova-T is the card that uses the terrestrial signal.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Well I assume you would get the FTA terrestrial channels but the subscription channels won't be accessible since it lacks a cam slot, wouldn't it be more practical to get a FTA reciever instead of something that only works if it's in a PC?
  3. AndTheAce
    AndTheAce
    I already have cable (digital) TV installed but was thinking of using it in the spare room upstairs.
    If ITV Digital go, does this mean the FTA channels will disappear?
  4. Pyara
    Pyara
    As far as I am aware the ITV Digital transmitters are not actually owned by them but by the government. You should still receive the FTV transmissions.
    ITV Digital was a company incorperated to jain subscribers to additional channels on these transmitters, those channels will indeed no-longer be available if they go under.
    Personally I would invest in a satellite decoder card...
  5. Yoleus
    Yoleus
    Apr 15, 2002
    7
    4
    Leicester UK
