has tosh got panny tube?
Discussion in 'General TV Discussions Forum' started by stranger, Jun 29, 2002.
  1. stranger
    stranger
    got a tosh 36 p/frame today and just noticed centre dot on each side of screen-does this mean tosh use panasonic tubes as well as philips?
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,912
    71
    50 Rue St Georges, Paris.
    +32
    Toshiba Picture Frame models exclusively us Toshiba microfilter CRTs.
  3. stranger
    stranger
    thanks for that quick response- having a panny tube was one of the things that put me off a pixel plus.
  4. Squirrel God
    Squirrel God
    The dots on each side are common to many manufacturer's tubes. They're used to help with geometry alignment. Philips and Sony are exceptions as they use a different approach.
  5. gallus23
    gallus23
    Jun 30, 2002
    65
    Godmanchester, CAMBS
    I've just been lusting after one of these at my local retailer.
    I know its done well on the award stakes but Whats your opinion of the TV ?
  6. stranger
    stranger
    i'm still playing with the picture settings, it's my first 100Hz tv and the picture looks different to my sony 32" 50Hz (not necessarily better yet) can't fault it on dvd or digital cable though. geometry is out a bit and some very slight colour staining in two corners will degauss tonight, any advice on picture settings from owners would be appreciated.
  7. Squirrel God
    Squirrel God
    Stranger,
    Orange posted his settings for this set a while ago. If you do a search for his posts, you should find them.
