has the flash worked?
Discussion in 'Desktop & Laptop Computers Forum' started by Gazz, Jul 27, 2002.
  1. Gazz
    Gazz
    Guys (and Gals)
    setting up the new HTPC, and I've just taken the plunge and flashed my GCC-41270B 2.01 combo (thought I might as well do it from new)
    However, Drive Region Info V2.1 still says the drive has region protection. Does this sound right?
    Sorry if this is a daft question but I expected to see something different.
    Thx
    Gazz
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    I'm guessing here, but is it a LG drive? And are you sure you have the right model number as I can't find a GCC-412070B.
    Can find plenty of GCC-4120B's though so I'm guessing that's the one you have.
    There isn't an RPC1 firmware available yet for this drive, but there is a tool that allows you to reset the region code here Got the link from this page
    There is also another wee app called RPCMAN that can do this -
    link
    A good place to find out about firmware upgrades and any region free stuff is http://forum.firmware-flash.com/index.php?sid=e6aca293de63a4e3fc9b66194c01f816
    Finally got a firmware for my Pioneer DVR104 to make it region free from here :)
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    As above, make sure you have the right firmware. Also what OS are you using? If in XP, you need to make sure you create a DOS startup disk to get into "Pure Dos" (doesn't really exist with XP but anyway) mode.
    If it flashed correctly, it should have taken a few secs to a few mins with no error messages reported. If Drive Info is still showing a locked status then it probably still is. There is another utility though that is supposed to be more reliable than Drive Info. Check out the link to the forums that alanrob gave above. It's a great source of help for firmware flashing.
    I did my Tosh 2502 laptop drive last night and it worked a treat. You still need to get round the software side of things though and the best app for this IMO is Region Killer 2 available freeware from:
    http://elby.ch/english/fun/software/index.html
    Let us know how you get on . :)
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    Make sure you don't have more than one region reporting piece of software running.
    I flashed my Liteon drive, but according to DVDGenie, it was still locked. I tried it in another machine, and it was region free.
    It turned out it was because I still had Region Killer running, and that was telling DVDGenie that the drive was the region of the last disk I played. I stopped RK from running and rebooted, ran Genie and it was showing as region free.
    Gary.
  5. Gazz
    Gazz
    Thanks Guys - I'll try out your suggestions
    I'm using XP, but I must admit I'm pulling my hair out installing cards.
    GeForce 2 keeps conflicting and hanging the machine, and getting the WinTV applications and drivers in was an absolute mare (had to install the apps one by one manually off the cd and I'm still not sure it's right).
    I can't face trying to install the sound card tonight.
    I've got to be honest, if it wasn't for the help on this forum I would currently be mad/broke/dead/needing a new window after throwing the pc through it.
    I'll rejoin the battle of wits with the box tomorrow and let you know how it's going.
    Question - is it worth dumping XP and installing an older OS to make things easier?
    Gazz
  6. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    I quite like XP myself - it offers a lot more control over advanced features etc. but I can forsee problems when building from scratch. If the sole purpose of your HTPC is just that, for playing DVD's, then there is no real benefit in using XP over the likes of Windows 98.
    Stick it out a bit longer though and see how you get on. :)
