has sky+ only got 1 rgb o/p?
Discussion in 'Sky Digital TV Forum' started by Halloween Jack, Nov 30, 2004.
  1. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    the manual says 1 o/p and 1 i/p. how do i connect my pana e85 and tv up? has it actually got 2? or do i need to split the signal.
    cheers
  2. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    Yes it has only 1 RGB output - the second scart will input RGB but only output composite. The box does also have an S-video output.
    Can you perhaps daisychain the sky box through the E85 to the TV, though this depends on whether you're only likely to be recording from the Sky+ box in the first place. If you want to record from another input whilst watching sky this won't work.
  3. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    thx i'll do that for now. it seems weird though. so the vcr o/p of the sky box goes to the tv and vice versa.
    has anyone got any thoughts how have you all connected it?
    is it possible to split an rgb signal?
    thx
  4. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    Plug the E85's RGB output to the TV.
    plug the Sky+ boxes TV scart to the RGB input on the E85
    Make sure the sky+ box is set to RGB.
    It might otherwise just be worth trying connecting the sky+ to the E85 via s-video and L/R audio connectors, to the TV via the TV out scart.
  5. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    yep, i tested it earlier and it looks good. i thought rgb in series might cause probs but it's fine. and if i do need to watch sky direct i've still got the composite scart. it's still kinda weird that the sky box only has one rgb o/p and a rgb i/p? oh well.
    thx laura.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    All SKY hardware is made to a budget, when it was designed there was no need for a RGB scart to feed the millions of VCR's and there were no other recording devices that could take RGB anyway.
    The price difference between a composite and rgb scart may be only be peanuts but considering they have made over 8million units that soons becomes a BIG figure:)
  7. Halloween Jack
    Halloween Jack
    Sep 27, 2004
    275
    16
    fair enough. :)
