Palnow16
Hi I'm after a bit if advice. I've got a denon 201 separates system paired with diamond whafdale 9.1s.
There's no sound coming from the speakers. I've checked the connectors and when plugging in headphones sound is played. Do you think my 15 year old amp has died?
I've had problems in the past with the bare wire connections into the hifi, I'm wondering if the wire touching the back of the unit would have damaged it or if its just old. I've ordered a cheap replacement connector to check if that might fix things...
If I have to retire my faithful the amp, I'd be hugely grateful if you experts could recommend where I could source a replacement or an updated version of my system. Thanks in advance
