Has anyone varnished their speakers?
Discussion in 'Home Cinema Speakers' started by Chrisharry12345, Feb 13, 2014.
  1. Chrisharry12345
    Chrisharry12345
    Nov 25, 2008
    4,454
    2
    +1,257
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    A vinyl wrap may be an easier option.
  3. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,356
    +4,211
    The thing you need to remember is that the outer finish is not likely wood on an inexpensive speaker like this. Likely it is some type of vinyl. You could potentially darken the finish, but you need to make sure what ever finish you use is compatible with plastic. That's not that hard to do, but it is relatively important.
    Steve/bluewizard
  4. Chrisharry12345
    Chrisharry12345
    Nov 25, 2008
    4,454
    2
    +1,257
    I tried a varnish on the vinyl and it did nothing.. I might have to look at vinyl wrapping :/
  5. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    Is swapping speakers an option? I would think the detriment to the value of your speakers and the cost of the wrap itself would probably outweigh any financial cost of swapping. Presuming you can actually find speakers in the colour you like of course
