Has anyone used their Sky box thru the component output on the RDXS32 ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Taz69, Nov 4, 2004.
  1. Taz69
    Taz69
    Apr 15, 2002
    3,259
    Bristol
    +304
    Hi guys and girls, just wondering if anyone has used a sky box via the RDXS32 through the component out to a display such as a Plasma/LCD or PJ ?
    Looking for opinions on picture quality and difference from the scart version etc.
    Thanks in advance
    Taz :thumbsup:
  2. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    taz, I use my tosh as the projector source and view everything through it including Sky.
    previously I used sky on the projector using an RGB to VGA concerter. But the tosh gives far better results. the prog scan on the tosh is better than the one on the projector (IMO)
  3. Taz69
    Taz69
    Apr 15, 2002
    3,259
    Bristol
    +304
    Cheers for the reply m8, am i right in assuming that if i do go the plasma route the tosh will provide a better picture for sky over the scart route, has anyone tried this option.
    Taz
  4. Taz69
    Taz69
    Apr 15, 2002
    3,259
    Bristol
    +304
    anyone else ??
  5. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    i have a plasma and i tried to use the progressive scan from my panny DMR-E85H to view sky and freeview, the quality is actually worse than my straight RGB scart connection although i have just ordered some decent component cables as the ones i tried were rubbish.
  6. Taz69
    Taz69
    Apr 15, 2002
    3,259
    Bristol
    +304
    cool Clive can you let me know the results please.
    Taz
  7. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    will do, hopefully the cable will arrive tomorrow
  8. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    well got the cables and i saw a marked improvment in quality, overall on sky and freeview i think RGB is still better, the edges of the text seems fuzzy on componant. Not tried a DVD yet so i cant comment on that.
    maybe your progressive scan player will give better results
  9. Taz69
    Taz69
    Apr 15, 2002
    3,259
    Bristol
    +304
    Great m8, does Sky sports etc have blur on the edges of the pitch signs etc has the picture scans round ?
    cheers
    Taz
  10. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    yeah it still hates the movement on footy games, i think thats more down to the amount of compression sky use than anything else
  11. Nicky
    Nicky
    Nov 5, 2003
    179
    +5
    I'm using the Tosh to convert RGB from an STB to component for a plasma. It's replaced a JS tech RGB->VGA converter. The pic is okay but the JS tech box was better. I'd be surprised if going the component route is better than straight through RGB. Plus it's worth baring in mind the conversion doesn't happen with the Tosh in standby (=fan noise) and you lose the widescreen switching signal on the scart.
    Flip side is component is great for DVD playback so it would be a shame not to use it.
  12. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    yep i agree with that, just tried a dvd and the pic quality was excellent
  13. Taz69
    Taz69
    Apr 15, 2002
    3,259
    Bristol
    +304
    cool, thanks for the info guys, glad to hear the dvd picture is very good.
    Thanks again
    Taz
