has anyone used a Xantech CC12 before?
cameronl
hi there, I am thinking about purchasing the Xantech CC12 along with the remote to program it.
Has anyone used this device before? If so, is it a simple case of putting in 2 wires from my 12v trigger cable (ala speaker cable) and then using the remote to trigger it?
thanks
CaM
richardbarman
you'll also need a IR reciever, like the Xantech 291-10 'Hidden Link' to actually get Ir into the CC12, and a 12v supply.
It works well, and the codes can be easily learnt into a macro on a remote.
Richard
cameronl
hi there, thanks for you reply.
so what I need is the following then
Xantech 291-10
Xantech CC12
Xantech RC68+ remote
I guess this setup would give me good scope for other 12v trigger situations as well.
thanks
CaM
