has anyone upgraded from Yam A1 to AZ1?
Discussion in 'AV Receivers & Amplifiers' started by Dave H, Feb 20, 2003.
  1. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    Hi I am thinking of upgrading myself and want to know your thoughts.
    Is there much differance in the power output of the amp, does it feel more powerfull or is it just another speaker at the back?
    I would like your opinion as it will cost me about a grand to upgrade.
    cheers Dave.
  2. nbn
    nbn
    well i had a dsp a1 and went for the dsp az2. i found this amp to b much better . its not so basey as the a1. and more detailed. than the a1. plus this amp was a lot cheaper. but if i had the money. i would have got the az1. if i was you take a listern. or upgrade
  3. Dave H
    Dave H
    Aug 20, 2000
    4,393
    +144
    There must be someone :(
  4. Dave H
    Dave H
    Aug 20, 2000
    4,393
    +144
    not a popular choice of amp then :confused:
