nheather
Outstanding Member
I have an intermittent fault with my BK XLS200?
Every now and then it will rumble loudly when switched on. It is not the source, when I disconnect it there is no difference. Also the gain control makes no difference.
To ‘fix’ I switch on and off until it stops. The sub then works fine until the next occurance which might be in a few hours or a few days, there is no pattern. Sometimes a single off-on cycle will do the job, sometimes it takes more, as many as ten in the worst case.
My suspicion is that the electrolytic capacitors are failing with age - I’m half expecting to find them bulging and/or leaking.
That is if I could get at them.
The back plate has 12 hex-socket head screws - I have removed them but the back plate doesn’t budge to gentle force - I don’t want to try brute force in case there is anything else I should remove.
The only other possible fixings that I can see are three screws in the heatsink but not touched those in case they are just securing MOSFETs on the other side.
Anyone removed the back of one of these - is it just those 12 screws and pull hard or is there something else to do.
I eMailed BK months ago for advice but they never replied.
Cheers,
Nigel
Cheers,
Nigel
