Has anyone solved H30 smearing / blurring prob?
Discussion in 'Projectors, Screens & Video Processors' started by stifler, Feb 10, 2005.
  1. stifler
    stifler
    I'm new here, but was able to see ppl reporting the same issue I'm having with my H30, i.e. the smearing of colours and blurring of the picture.
    I couldn't find anybody reporting a solution to the prob so far.
    Is there a fix for this, since I've tried all possible settings on the PJ, prog scan and interlaced, component cable and S-video, two DVD players, but no results. My firmware is c07, and I watch only PAL R2 DVD's.
    thanks folks!
    /stifler
  2. MikeD
    MikeD
    Mar 17, 2001
    265
    Paignton, Devon, UK
    Got my H30 last April, never had any problems with smearing or blurring just a fantastic picture all round.
    Only ever had it connected RGB from SCART on an SVGA cable though so perhaps thats worth a try, you should have had a SCART adaptor supplied with it.
    Optoma claim somewhere in their advertising blurb that the H30 is optimised for RGB and that its as good as component although I know some purists on this forum would argue that theoretically it couldnt be.
    MikeD
