Has anyone removed the case from a TX100?
Discussion in 'Projectors, Screens & Video Processors' started by UrbanT, Oct 16, 2004.
  1. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    I have found some french instructions, which don't really help.
    Don't want to force anything, and can't figure out how to remove the top silver part to get to the panels? Anyone help? :)
  2. Claude
    Claude
    Hi there,
    You might want to look at a post from about a month ago named 'duct blob on tx100'. or something like that.
    Someone tried it but couldn't get it past the lens. If it is a dust blob problem that you are seeking to rectify the solution was to us compressed air in any orifice possible.
    You might want to check it out before before giving your PJ a BJ.
