Has anyone heard of.......
Discussion in 'Shopping, Deals, Discounts & Bargains' started by toots8298, Jan 22, 2005.
  1. toots8298
    toots8298
    Hihi
    Was wondering if anyone has heard of or used
    Blahdvd?
    I stumbled across it and Fraiser season 1,2 and 3 is only £14.99 per season, which is pretty good.
    Any response would be appreciated!!! :thumbsup:
  2. sdss
    sdss
    Sep 30, 2003
    52
    they are jersey based - so the postage takes a fewer days longer than normal. I've used them a couple of times - they're not the fastest company but okay. (there was talk of them being linked to SplashDVD (another jersey based dvd store which went bust - and whilst they deny it - they started up as the other stopped and had an almost identical website).
  3. Rob20
    Rob20
    Jul 3, 2004
    2,619
    103
    +354
    Blahdvd was the company that put PES4 for the XBox on their website for £17.99, only to increase it to £31.99 after loads of people had pre-ordered and then refused to honour the £17.99 pre-order. I wouldn't use them personally.
    www.play.com sell the 1st 2 season for £15.49 inc. free del. :)
  4. toots8298
    toots8298
    Thank you sooo much for the heads up!
    Will take your advice and steer clear of them me thinks..... ;)
    Cheers!
