Has anyone got TVRemote from PDAWIN to work with Sky+?
johndon
Subject says it all really - has anyone got this to work.
I can get most of the keys to work with the exception, so far, of:
5
9
Backup
Yellow Button
It seems bizzare that the two numeric keys in particular don't work as all the others do.
John
M
morphman
I have a pronto CCF that works with Sky+ (The old version 1 box and remote).
I created it myself, with learned functions and it works on PDAWin and my Ipaq 5450.
mail me at [email protected] if you want a copy to play around with.
johndon
Thanks to morphman, I've got almost everything working now - the only button I still can't get to work is the yellow button.
John
sjhanson
Hi, long time lurker, very rare poster here!
Johndon, I have the same problem as you. Managed to get all the buttons to work except the Yellow one. Have you found a solution yet?
johndon
Hi Shaun,
Not yet, I've tried every ccf I can find on Remote Central and still no luck.
I haven't given up yet but I'm getting close...
John
Messiah
Worked fine on my Axim with TV Remote when I had it. If you want my CCF (Sky+ device panel) drop me a PM with mail address and I will send. Meanwhile, try this IR hex code
0000 0073 0000 0017 0060 001f 0010 0010 0010 0010 0010 0020 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0010 0010 0020 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 1059
sjhanson
The strange thing is that when a friend uses my ccf on his old ipaq 3850 the learned 'Yellow' code works fine, but not on my newer 2210, even though it was my 2210 that 'learned' the code.
We are both running the same version of the pdawin software but he is running an older operating system on his ipaq. He is also using the ir extender.
Very frustrating!
johndon
Well, I've finally got it sorted. Messiah kindly sent me his CCF on which everything worked apart from the yellow button again. So, in desperation I tried learning the button again and incredibly it now works fine :clap:
John
Messiah
Strange. But very glad it is now working OK.
I had a similar issue last night with the TV volume+ key on a TSU3000 PCF I was creating last night. Took 5 attempts to get it working. I often find the best way to learn the codes is to use 2 short presses rather than one long one. Out of desperation I will often revert to using Tonto which does a compare of 2 captures. Why on earth Pronroedit does not learn from that and implemenmt a similar checking procedure I will never know.
sjhanson
Thankfully so does mine!
Used Messiahs tip and pressed the key twice in quick succession and it now works ok!!
Result!
SimonO
Agree with Messiah... Use Tonto to learn the codes, it's far more consistant than PE...
LG CX 4K OLED TV Review: The best TV of 2020?
