has anyone ever seen these fans?
Discussion in 'Xbox Forums' started by geowars2, Apr 24, 2007.
  1. geowars2
    geowars2
    Jul 29, 2004
    651
    +22
    I was looking for replacement xbox 360 fans on ebay, and i asked the seller if he had any more (as i was looking for the better unstickered ones):
    He sent me the following picture:
    [​IMG]
    has anyone ever seen these before? :eek:
    if so do you know if they are any good?
  2. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
  3. geowars2
    geowars2
    Jul 29, 2004
    651
    +22
    thanks for that link :thumbsup:
    i dont mind if they're noisy as long as they did a better cooling job than my current xbox 360 fans!
    also the seller of these fans said they are official and came out of an xbox 360 :rolleyes: i asked if it was a newer or older model 360 they came out of but he didnt know.
    anyways i still dont know whether to buy them :confused:
  4. RandomLee
    RandomLee
    Feb 17, 2006
    9,175
    Just check my IP address
    +2,948
    If they really did come out of a 360 then I doubt they would be any better than your current fans.
    If I was you I'd check out xbox-scene forums for the best colling options ;)
    Did you decide against Talismoon ones in the end?
  5. Russellgti
    Russellgti
    Nov 4, 2005
    523
    28
    +29
    Don't bother with the Talismoon fans as they are significantly noisier. But if noise doesn't bother you then they do shift more air than the standard ones. They are different to the ones in my 360, I think that mine are made by Delta and described as brushless rather these maglev ones. Mine is a launch console, which still working (Touch Wood).
  6. geowars2
    geowars2
    Jul 29, 2004
    651
    +22
    yep they're crap !! :rotfl:
    im looking for the original black fans, which dont have a sticker on the front of them. As i mentioned before my brother has these fans in his xbox 360 and his fans are much quieter and push out more air meaning his 360 is cooler (and doesnt crash)
    thing is i cant find them anywhere!
    also i've had a look on xbox-scene. Theres a few things i would like to do like adding ram heatsinks and using Artic Silver but not right now :smashin:
