Has anyone compared Velodyne SPL800i vs Monitor Audio RSW12
Discussion in 'Subwoofers' started by Don Guido, Apr 30, 2007.
  1. Don Guido
    Don Guido
    Apr 12, 2007
    115
    +3
    Hello everyone,
    Just wondering, has anyone had the chance to compare the above two subs?
    I am really stretching my budget by going for the Monitor Audio Radius R90AV-12 system, I could save a couple of hundred quid if I switched out the RSW12 sub and replaced it with the Velodyne sub.
    I have had a demo of the Velodyne and the MA360 subs which imho the Velodyne won.
    Does anyone have any thoughts?
    Kind regards,
    Guido
  2. Don Guido
    Don Guido
    Apr 12, 2007
    115
    +3
    anyone out there ?
  3. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Hello Guido and welcome to the forum.:)
    To be fair, it would appear you may have answered your own question, but have a look at this thread as it's along very similar lines.
    It'll possibly throw a couple of names up that you may not have heard of before.:smashin:
    What in particular made you prefer the Velo over the MA? As I say, this question has cropped up before and it'd be nice to hear your thoughts.
    Russell
  4. Don Guido
    Don Guido
    Apr 12, 2007
    115
    +3
    Will read the thread you posted in a minute, I preferred the Velo sub for a couple of reasons, firstly - it was well finished and very dinky size wise, therefore helping with the wife factor.
    Secondly, compared to the 360 the bass - to my untrained ears - seemed less boomy/waffly (Im a noob at this so not sure how to explain it properly)
    I haven't heard the RSW12 though.
    I also like the idea of buying a sub from people who specialise in subs, I guess it doesn;t hurt though that the Velo is cheaper - although in an adjunct to this post it turns out that I was listening to the SPL800R, so the much vaunted automatic tuning/equalising that I though was really cool doesn't come with the £500 SPL800i :rolleyes:
    Kind regards,
    Guido
  5. Donald.Elliot
    Donald.Elliot
    Nov 12, 2006
    34
    I'm on a similar mission (audio sic !) to decide between the RSW12, and something else ... Why ?
    Because the RSW12 is rather large, so I was wondering about something from the REL range for example the RS305 is positively pocket sized by comparison, or even a REL 505, S* series etc etc.. Then there are the Velo range that you just mentioned.. Not wanting to hijack your thread but there seem to be a number of us at the moment looking for better bang for our buck or the same or better performance in a better package ...
    To think I was going for the RSAV 6 package a few weeks ago. Once you start swapping bits out you can't stop !:)
  6. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    6,170
    2
    2
    Bromsgrove
    +651
    SVS SV12+ has to be on the list, 13" cube, looks good and less than £500 (the same as the Velo!)
  7. Don Guido
    Don Guido
    Apr 12, 2007
    115
    +3
    Having now heard the Velo and the SB12+, I would actually put the SVS sub ahead of the Velo. To my ears it just provided deeper, tauter bass and a more of it too boot!
    The only cavest though would be that it is cheaper £460, but that's only in matt black, if you want some of the very nice wood finished, then it would actually be an extr £100 on top, so therefore £60 more expensive than the Velo.
    Both are excellent subs mind you, to be honest.
    DG
