I'm starting to wonder if my speakers have blown as they are sounding harsh at high volume. Can someone check over my settings to see if they are configured properly?
Av receiver is a Pioneer VSX-323. Speakers are Tannoy TFX 5.1.
Crossover is set to 80hz on the receiver.
Subwoofer is switched to AV/LFE on the back. Crossover on the subwoofer is turned up to the max at AV/LFE. Bass level on the subwoofer is set to just under half, although I find it overpowers the sound sometimes.
