Harper Windows?
Discussion in 'General Chat' started by red2004devil, Jan 15, 2008.
  1. red2004devil
    red2004devil
    Jul 13, 2004
    217
    Hi. I was wondering has any1 used harper windows cus ive got a bloke cuming saturday to give me a qoute becus i heard on the radio that they were doing 5 windows and 1 door for £1500
    http://www.harperwindows.co.uk/
  2. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    No idea to be honest , what i did notice is that it is a trading style of NMW WINDOWS LIMITED , might be worth checking up on them as well for any horror stories ;)
  3. paul1967
    paul1967
    Dec 26, 2005
    1,258
    48
    +65
    Ask if they use virgin plastic to make the windows if not it stains yellow over time also that they have alloy reinforcing inside the plastic frames,as they will bow over time,price sound alright,its there slow time of year,also ask if its there own fitters or contract ,you are better off it's there fitters.
  4. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    looking at there website they use a good make of frame , forget the name now and i cant be bothered to look , as for the reinforcing , it does add strength and security to the frame , not sure if it is needed to stop the frames bowing , proper fixing stops that , i used to fit the stuff and saw plenty of bowed headers where they were not fixed or packed properly :mad:
