Harmony885 Remote with Bang & Olufsen (B&O) ??
Discussion in 'Home Cinema Control & Remote Controls' started by OxfordJohn, Aug 9, 2005.
  1. OxfordJohn
    OxfordJohn
    Jul 12, 2005
    10
    Is anyone using a Harmony 885 with B&O kit? The test drive tells me that it’s possible but the FAQ says NO. This negative view was reiterated in an email from Harmony Tech. Support “I unfortunately have to inform you that at present none of our Harmony Remotes can control Bang & Olufsen devices.” Does anyone have any actual experience?
    OJ
  2. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I thought I read somewhere on the Logitech site that they were working with B&O to sort this but I may be mistaken.
  3. noel-pilot
    noel-pilot
    Dec 20, 2004
    Is B and O stuff Infra red?? I always thought it was RF as I remember my mates tv could be controlled from the heavyweight brick remote anywhere in the house and the cordless phone could turn the tv up and down.!!
  4. OxfordJohn
    OxfordJohn
    Jul 12, 2005
    10
    Yes, definitely IR, but not ‘normal’ IR – the modulation frequency is higher that that used by practically every one else.
  5. psflynn
    psflynn
    Nov 10, 2003
    338
    Swindon
    +4
    Unfortunately (for you) i have found the harmony technical support to be very helpful and accurate! If they say no im sure the answer is (currently!) no.
  6. OxfordJohn
    OxfordJohn
    Jul 12, 2005
    10
    It’s taken a few weeks of tweaking by Harmony TS but I can now control my Beocentre 9000 with my H885. As psflynn said, they are very helpful - and very tenacious too it would seem. Many thanks to Terrence at Harmony TS.
