Jezza99
I recently swapped out my Pioneer LX55 for a new LX79, which I am very pleased with. However, I do have a small issue now with my Harmony remote. With my Previous LX55, all worked perfectly, but having set up the LX79, I have the following issue:
If, for example I am watching a Blu Ray, then switch to "listen to Tuner" via the Harmony, all is fine, ie the TV and Blu Ray player shut down, and the amp switches input to "Tuner".
But, If I am watching Blu Ray, switch everything off, then come back and hit "listen to Tuner" on the Harmony, although the correct piece of kit wil switch on, the amp is "stuck" on the Blu Ray input. Then when I press help on the Harmony, it switches it to Tuner input, and all is ok.
This applies to all inputs, ie when switched off, the amp seems to be "stuck" on the last input used. and needs the Help button pressed to function, but one the kit is switched on, I can switch between any activity and it works fine, without having to use "help".
I did try completely deleting all devices and activities, and set everything up from scratch again, but it has not fixed it.
Any ideas please ?
Any ideas please ?
