B
Bryce Curdy
I've got a funny problem using my Harmony 655, although I suspect the problem is not specific to this model or even manufacturer and could be fixed with some programming changes.
Last thing at night or first thing in the morning I sometimes like to burn a film onto a DVD using my DVD/HDD recorder. Having set it all up, I then use the Harmony to turn off the power on my TV and AV Amp before going to bed/work. Once the recording is complete, if I use the main OFF button on the Harmony, it correctly 'remembers' that the TV has already been turned off, but must send a power toggle command to the AV Amp which turns it back on again. It makes no difference whether I switch the AV Amp off using Power Off or Power Toggle (accessed through DEVICE), and setting up a Power Off command as an additional button also does not help.
Very grateful for any help.
bryce
bryce
