Harmony Software for Vista available now
Discussion in 'Home Cinema Control & Remote Controls' started by eibborc, May 7, 2007.
  1. eibborc
    eibborc
    Oct 25, 2000
    84
    Edinburgh
  2. BaggieBoy
    BaggieBoy
    May 3, 2004
    38
    I installled it a couple of days ago, works fine. No problem with Aero.
  3. ipace
    ipace
    Feb 7, 2007
    +13
  4. BaggieBoy
    BaggieBoy
    May 3, 2004
    38
    They kept saying an update would be available "sometine in April", then May arrived and it changed to "available soon"...and it was!
  5. Mr Mike
    Mr Mike
    Jul 27, 2006
    197
    Aberdeen-ish
    +10
    Just installed the vista software on my new laptop after being without it for last few months. Problem is it wants me to configure the device, nothing is set and when i logon to the website its exactly the same. This is REALLY ANNOYING!!!!!!
    Too scared to plug in remote, get the feeling it may blank it to match the web.
    How do you find your config that was stored on web?
  6. string
    string
    Oct 10, 2005
    123
    +4
    Update is avail for OS X too, anyone know what is new?
  7. Mr Mike
    Mr Mike
    Jul 27, 2006
    197
    Aberdeen-ish
    +10
    Slap on the head for me, used the wrong username which had never been registered which is why it was blank, logged on with correct username and everything is fine.
    The joys of installing something over a year ago then having auto logon setup.
