Harmony Setup Question
Discussion in 'Home Cinema Control & Remote Controls' started by jason44mag, Mar 21, 2006.
  1. jason44mag
    jason44mag
    Jun 21, 2005
    2,746
    71
    Nottingham (In NZ at the Mo)
    +46
    Hi all
    Just a quick harmony setup question.
    When selecting your gear where do you chose the sky+ box i.e which category satellite, pvr set top box etc and im using a pace v3 (i think) so which model do i chose?
    thanks in advance :smashin:
    Jason
  2. Jordans Norks
    Jordans Norks
    Feb 16, 2005
    1,700
    48
    +56
    I think you can eventually select the same gear when you drill down under PVR, Sat etc it's just the activities that are name different (wtach PVR instead of....)
    It's defo under PVR though!
