Harmony Remotes? Real Help Needed ASAP
Discussion in 'Home Cinema Control & Remote Controls' started by betty02, Sep 14, 2007.
  1. betty02
    betty02
    Jun 2, 2007
    92
    11
    Ive been looking at some harmony remotes, ive seen the ones with the screen on were you can programme it to say 'Whatch Sky TV' and when you press it then it can turn on Sky, dim lights and turn the amop to sky at the same time and then say another saying 'Whatch Cinema' which will turn all lights of turn the projector on, pull screen down and trun amp to projector, or dvd or whatever
    Now this is a great feature but my Tv is really old toshiba one, and my freeview box is a crappy matsui one will it work with them?
    projecotr is NEC, and i have lights with a remote by Varilight
    Now can i say just not use the touch screen function point the remote at say the freeview box and it will change that without doing all the actions?
    Or am i best of getting a kamelion 8303?
  2. betty02
    betty02
    Jun 2, 2007
    92
    11
    Ok ignore me ive answered myself by searching cheers ordering a 525 soon!
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    as long as you have the OEM remotes yes (and they are IR) yes you can do it!
