Harmony Remote Software vs MyHarmony.com
Discussion in 'Home Cinema Control & Remote Controls' started by doowruc, Jan 8, 2012.
  1. doowruc
    doowruc
    Aug 17, 2011
    182
    Kent, UK
    +25
    I'm trying to decide between a One and a One+ as they are both on Amazon but with the One being £40 cheaper than the One+.
    What are the advantages / disadvantages between the Remote Software vs MyHarmony.com?
    For example, from what I read on the Logitech website, for the 700 the Software allows only 6 devices whereas MyHarmony.com allows 8 devices - a huge advantage to the web setup.
    Will Logitech do similar things with for the One+ which then wouldn't be available for the One?
    Are Logitech halting development of the Software in favour of MyHarmony.com?
    How does MyHarmony.com tell the difference between the One and One+? (hardware difference? firmware? serial number?)
    Apologies for the many questions!
    TIA
  2. logiciel
    logiciel
    Feb 2, 2008
    53,014
    UK
    +5,729
    The two are identical so if one is cheaper than the other then that's the one to go for.
    The web site that the + version can use is inferior to the normal set up procedure.
    As far as I know though it is only the cheaper models that it restricts to a small number of devices.
    Logitech don't do any development of software so that point doesn't arise.
  3. chris6
    chris6
    Apr 8, 2010
    103
    UK
    +16
    I read that they are identical, as logiciel said, and that One can handle up to 15 devices.
    It was also stated that they could both use either myharmony.com or v.7.7.0 Software.
  4. Flimber
    Flimber
    Sep 22, 2002
    13,716
    Yorkshire
    +4,483
    The site won't let my One chat to it, got to be the software.
  5. doowruc
    doowruc
    Aug 17, 2011
    182
    Kent, UK
    +25
    Forgot about this thread!
    I bought a One from Amazon as it was £40 cheaper than the One+
    I can confirm that they are identical: If I connect it to the 7.7.0 software it is recognised as a One, if I connect it to MyHarmony.com it is recognised as a One+
  6. doowruc
    doowruc
    Aug 17, 2011
    182
    Kent, UK
    +25
    That's odd. Mine is a One (there is no + anywhere on the packaging and it came with a CD with v7.6.0 software) and it works with both.
  7. Flimber
    Flimber
    Sep 22, 2002
    13,716
    Yorkshire
    +4,483
    How did you geddit to do that ? Or did it just do it ? :(
  8. doowruc
    doowruc
    Aug 17, 2011
    182
    Kent, UK
    +25
    It just did it!
    I set it up using the software first, then I wanted to see what the differences were in myharmony.com
    I had to set up a new account in myharmony.com as I had previously used it for my old 650. When I logged into the new account it detected my One as a One+.
  9. logiciel
    logiciel
    Feb 2, 2008
    53,014
    UK
    +5,729
    As you said, in post #5.;)
    It's another Logitech oddity - I'll check mine later.
