I have been a long-time lurker on the avforums for various things. Have picked up much good advice and tips, so thanks to you all. Decided i had better finally join however.
I am not sure which forum was best to post my question but this seems the most sensible place to start.
I have a harmony remote control that i am trying to use with my newly built HTPC and the rest of my set-up, which includes a V+ box. Seems to be working reasonably well, except the problem i have is that certain button presses on the remote when using the V+ box (direction right or left i believe) turns the HTPC on or off (Pwrtoggle) at the same time.
All i can surmise is that there is a frequency clash with the signals being sent.
I am actually quite surprised that i cant seem to find anyone else suffering from this problem through searches on the internet.
So my questions are:
Has anyone else experienced this?
Any ideas to a way to resolve this? (Through changing frequency of IR signal on my HTPC or any other method).
I'm using an Antec Fusion black case for my HTPC (with built in IR reciever).
Many thanks
Many thanks
