Harmony remote charger help
Discussion in 'Home Cinema Control & Remote Controls' started by Madkitty, Dec 24, 2006.
  1. Madkitty
    Madkitty
    Jul 21, 2005
    382
    It looks like my ac adapter has gone and snuffed it just when the remote was flat!!! Typical for xmas eh!!!
    Does anyone know a temporary way of charging it and also whether I can just get a replacement that will work from somewhere like maplins on wednesday? Its not the fuse have checked that :mad:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    if you take it to maplins they should be able too sort something but take the remote too
  3. Madkitty
    Madkitty
    Jul 21, 2005
    382
    ok all fixed but im wondering whether i now have a problem with it holding charge - Im sure my screensaver stayed on all the time when it was in the charger?
  4. fizl
    fizl
    Apr 21, 2006
    2,164
    Not in London
    +460
    Isn't that based on the dimmer setting or something? Mine only plays the screensaver for about 15 seconds or something before it switches the back light off. Charges fine
    Shaz
