digitaldave
Established Member
I'm currently using a Harmony 650 remote to control my set that includes a Sky+ HD Box routed through an amp and out to the TV. I have CEC / HDMI control enabled as I use the Netflix app on the TV, and send the sound back to the amp so I don't have to use an optical cable. However, I've encountered an issue - sometimes when it's switched on to watch tv, the amp comes on muted. After researching, I think this is caused by a clash between the CEC / HDMI control commands and the commands sent by the remote. If I use the regular remotes, it works fine.
1) Is there a way to get the Harmony to send discrete commands? For example, if I want to watch tv using the original remotes, I just turn on the sky box, and the tv and amp switch on and set inputs correctly. So I'd like to duplicate that when I press the 'watch tv' button. As it stands, it's needs to send commands to turn on all three devices and set the inputs.
2) if I can set it to just send the sky power on command, how would I get the amp to control the volume? And get everything to switch off together when I press the 'all off' button?
3) If the above can't be done, are there any alternatives to the Harmony that would be able to do what I'm after? I had a quick look at some All4One remotes, but they seem to be set up around activities like the Harmony.
Thanks,
Dave.
Thanks,
Dave.
